primary seal leak
primary seal leak
Hi guys just finished putting bike back together after replaceing all the seals all the way back to gearbox seal on my 89 flht, I was extra careful with the mainshaft splines taping it up and lubing it for slipping the inner primary seal over it while reseating the inner to the gearbox and motor. its not leaking lots but it does show a leak. I'm using atf for primary ( 1 full litre) and gear lube for gearbox. I put a skim of red silicone around the outer edge of the seal reading somewhere this is a good thing. I used a james seal. Any ideas guys why this will not seal up tight?
Thanks
Lynn
Thanks
Lynn
seals
Thanks
Lynn
Thanks
Lynn
In my opinion all will be well as long as you have let the motor sit for 24 hrs. to allow the different sealents to set together.
If you have run to early , stop and again let the motor sit to attain the above curing .
Good Luck with this , let us know how it works out .
