Sponsored by: Jekill and Hyde
Exhaust nuts- loctite or not?
Old 05-27-2015, 02:42 PM
ckamin's Avatar
ckamin
ckamin is offline
Default Exhaust nuts- loctite or not?
Hey, what is the best way to set up a set of nuts after putting the header on my Street Glide? Loctite? Anti seize?
Thanks!
Carl
Old 05-27-2015, 02:50 PM
Coastal CVO's Avatar
Coastal CVO
Coastal CVO is offline
Anti-Seize
Old 05-27-2015, 03:04 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Old 05-27-2015, 11:44 PM
Stych's Avatar
Stych
Stych is offline
Loctite breaks down at temps WAY below what your exhaust is operating at. Rocksett may hold up, but still, anti-seize is the way to go.
Old 05-28-2015, 01:38 AM
ckamin's Avatar
ckamin
ckamin is offline
Cool, thanks!
Old 05-29-2015, 11:59 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,812 Likes on 3,316 Posts
If your going to anti-sieze them, just make sure you check them every 1000 miles or so for looseness.
Old 05-29-2015, 03:44 PM
Coastal CVO
My gasket kit came with new nuts that had a saraded flanges that bite into the retaining plate but you are spot on with the check them position, if nothing else the gaskets will tend to settle a little and if you don't tighten them, you could blow out a gasket in a short amount of time.
Old 05-29-2015, 06:20 PM
ckamin's Avatar
ckamin
ckamin is offline
Thanks guys! I used a dab of anti-seize and everything went back together just fine and works well. I'll check them again in a few hundred miles and make sure they are still torqued properly.
-Carl
specks (11-17-2021)
chitownslim
Touring Parts
04-17-2017 11:38 PM
Rickr01
03-09-2011 06:06 AM
KingEvo
EVO
01-30-2011 04:04 PM
craigffb
08-17-2010 02:43 PM
jamesdeanblvd
02-27-2009 04:39 AM
Quick Reply: Exhaust nuts- loctite or not?
