Internal Exhaust Coating
Eastwood is GREAT!
I have not used this particular coating, by I have used this same exact tube many times over to paint the inside of body panels on cars & trucks. The tube works very well and is reusable. I have one that I have used in over 10 cans of paint. The tube fits most Eastwood spray products. The tube will allow a good even coat all the around, but the paint will run.
This method is very, very messy. If you do paint the inside of exhaust, please do it off of and far away from the motorcycle. Also, make sure the heat shields are no where insight too. Didn't mean to insult anyone's intelligence.
Another idea is to get Eastwood's Paint Prep product as well. When you are done, take the tube off of the exhaust paint and put it on the can of paint prep and spray some cleaner thru it. This allows the tube to be cleaned out & re-used again.
Gonna try it!
I am going to try this product when I get my new exhaust. For $16 on sale, it can't be beat. I have a feeling that this product is just as good, if not better, than the expensive ceramic coatings offered by other vendors / suppliers. For less than the cost of shipping your pipes, you can get a can from Eastwood and be done with it. I have read nothing but good reviews and I have also heard it can be used on the outside of the pipes as well.
Eastwood Hi-Temp Internal Exhaust Coating
I plugged my oxygen sensors bungs and can't scratch the coating easily off the plugs, seems to be durable.
I've only run the bike about 5 minutes, when I get my new pushrods I'll see what the results are.
All hail Eastwood!
What color is this paint? From your pic, it looks blue. Did you use it on the outside? If not, what is your opinion on using it on the outside? I am thinking of using it on the inside, outside, and on the back of heat shield? I will carefully tape off the front chrome part of the heat shield before I start painting. I have several caps that I can install on the can to make it spray like a normal can of spray paint.
OldEnuf2NoBtr, I am really gonna !@#$ it up!
The picture is the inside of the crossover after I coated it, also I ran the motor about 5 minutes. The led lights on the camera give it a blue tint.
The coating is a flat silver. I painted part of the header that the chrome didn't cover, I'll post a pic later.
I didn't think of coating the heat shields, if enough is left I'll do it.
Two tips are include, the one with the hose and a regular spray tip.
