Sponsored by: Jekill and Hyde
Cat removal and tuners
Old 03-06-2017, 07:08 PM
Pyro1017's Avatar
Pyro1017
Pyro1017 is offline
6th Gear
Default Cat removal and tuners
I was told the other day that if I remove the cat from my headers or get a set without a cat I will need to have a tuner installed first or my bike will not run right. Can anyone confirm or deny this?
Old 03-06-2017, 07:40 PM
checkers's Avatar
checkers
checkers is offline
Assuming you have a Touting (FL) model, no you do not. Converters add no exhaust back pressure. That being clear, it will run better with a stage1 a/f, slip ons and a tuner such as an Fp3. Most bang for the buck, if you install them yourself.
Old 03-11-2017, 09:32 AM
randy04eglide's Avatar
randy04eglide
randy04eglide is offline
5th Gear
It will not hurt your bike. I ride a electra glide gutted convertor and gutted stock mufflers. It's a stage 1, cams and a tuner. When you take away backpressure you raise your torque peak, instead of your bike coming on at say 1800 r.p.m. it may raise to 2800. You hurt your bottom end. I saw it on my dyno sheet.
Old 03-11-2017, 10:13 AM
GregGillette's Avatar
GregGillette
GregGillette is offline
For me it was the change that needed the turner. I started with slipons and was fine. Next I did intake and added xieds in anticipation of needing more fuel. Seemed to run fine. Next I did decat and could not get rid of pinging and decel pop. I invested in fp3 last season and now it runs better than ever. For my model 2013 flhtc, the fp3 was not available until last season else I would have gone that direction sooner.
Old 03-14-2017, 07:44 PM
big- mike's Avatar
big- mike
big- mike is offline
I did the exact same thing on my 2010 ultra was using the old style Fuelpak then it took a crap last year and I went to the FP3 what a great improvement now it runs right.
Old 03-14-2017, 07:55 PM
kel03's Avatar
kel03
kel03 is offline
Received 6,044 Likes on 4,356 Posts
Going to do the same soon, so tagging on. Plus HF filter, SE pipes, and "old style" Fuel Pak I got a deal on. Hope all goes well.
touchdown
2014-2023 Touring Models
18
05-18-2016 10:19 AM
streetglide6
07-06-2015 08:57 AM
xprmntl1
04-27-2015 09:43 AM
morif
09-08-2013 09:00 PM
jojo2dog
03-29-2013 10:26 PM
Quick Reply: Cat removal and tuners
