How is your bike doing
Traded in my 2014 streed glide on a new ultra Low. This is my question:
I have always put headers and power commander on my bikes and dyno it.
Has anyone just opened the a/c up and just put mufflers on and just run it? how does it run and are you happy. I just don't want to spend the money this time.
RickLB (05-20-2016)
Did the same thing traded my roadking had cams kerker ex big ac purchase a 15 electra glide dec.14 didnt want to do all that this time must be an age thing this bike runs strong as is change out the mufflers put an fp3 on it change the a/c but didnt really make much difference the 103 high output is a great motor anything else is a waste of money unless u are running it a the strip
slip ons and a big sucker on my 13 rg , ran ok without a tuner, but, added a power vision and got a very noticeable improvement. On wifes cvo rk added the tuner only , stock otherwise, and also got an improvement. My opinion only , you can probably get by without a tuner with slip ons and a/c, but will gain little if any performance, but add a decent tunerfirst and you will be able to feel an improvement , and the tuner can be adjusted when you add anything else. FuelMoto has been very good to me as far as getting me a good base map for the powervision, and then let the auto tune tweak it after any upgrades
This might be unforgivable here but I'm running stock all the way. Traded a SE110 on the 16SG and I'm quite happy with the 103HO as is. I must be getting old as I tried a set of Klockwerks slip ons and thought it was way too loud. Very nice at idle but the minute you went to throttle, very loud. Still looking for a set of slipons somewhere between stock and and the Klockwerks.
whocares (05-17-2016)
I had an 07 Ultra that I bumped up to a 103, with SE race tuner, SE breather, polished ports with true duals, monster ovals and a few other tweaks with the compensator, clutch and cams. It was running perfect and I was very pleased with it. Due to a transport truck that wanted my lane, on the start of a cross country trip, the bike was totaled in 2014.
I then purchased a 14 Limited and went with SE street cannons as the only upgrade to the engine. It was a great bike and performed very well. A garage fire last year took that bike. I now have a 15 Limited and have made no changes to the engine. It is pure stock. I am very pleased with the bike, how it performs, and appreciate the quieter tone of the exhaust system. Maybe as we age we get more mellow.
Owning a Harley allows you to modify and personalize your ride in many ways, depending on your tastes and your pocket book. And what works for one does not for another.
After 11,000 km, this bike lives up to everything I want in a touring motorcycle.
Much like Wing rdr I had an 06 road king. Samson mufflers cams, rejetted carb etc. Bike ran great and sounded great. I now have a 16 Ultra Classic. I only have 1000 miles, but I don't forsee any need to change it. Maybe slightly longer bars for My reach but otherwise leave it and just ride!
I would put headers on if not just to remove the insane amount of heat that radiates from the catalytic converter. I have tried 3 different air cleaners and noticed no difference from the stock air cleaner so I have a feeling that would simply be for looks. I have also experimented with a couple different mufflers and don't think they are as corked up as we are led to believe. Removing the cat or changing the headers seems to be the best bang for the buck. Catless stock head pipes are between 100-150 bucks. A cheap set of FM head pipes can be had for less than 400 up to 600 for the stainless ceramic. You can then invest in a tuner like the Power Vision which you could then use on any other bike you buy in the future.
