Best cam for stock heads?
Still haven't decided on a cam. Seems like SE cams are not the best from what I have read. Here is my build 95 CI 10.25:1, V&H BS stag.,Big Sucker intake, SERT. Stock heads. Bike is 2003 FXSTi.
Which cam would be a good choice? I would like to see 90 hp 95 tq or better. Is the Andrews 44G a good choice?
Thanks
Thanks
RE: Best cam for stock heads?
10.25 with 44cam is 195ccp. That's high compression and will require a good tuner or it will ping. But don't assume that you've got 10.25 compression just because that's what the piston is rated. Have you measured the dome volume, chamber volume, deck height, etc? If it's really 10.25 I might move up to a cam with a 44 to 46 degree intake close.
fairbanks motors in johnson vt. uses them on some 95 builds. he has been getting over 100lbs. torque and around 100hpbuthe'll have to port the heads and install compression releases. ask for Drew, he will do theentire build with before and after dyno .#'s foraround $2500 using stock valve springs.can't give you the # because i'm at work right now.
