Which cam for a stock SE 110"?
I have an '07 FXSTSSE Screamin' Eagle springer.
the only mods are a set of Rush slip-ons with 2.25" baffles and a Thundermax ECM, otherwise it's a stock motor.
I have been considering installing a new set of cams to wake it up a little bit, I just don't know what would be a good choice.
I'm not planning on doing anything else except the cam change.
need some advice from my fellow forum members here![8D]
RE: Which cam for a stock SE 110"?
ORIGINAL: nmfxstc
Lotsa good talk about the SE 255s! Should maintain warranty, if that's a consideration, too.
ORIGINAL: nmfxstc
Well all cams have a compression range that they like, where they will work best. That engine is in the 9.1-9.3 range. You stated all you wanted to do was swap cams. With the engine being a 110 you have a bit of leway the with cam due to engine size, as well future upgrades. I would install the 54 cam by andrews. It will work well with the engine and has showen very good power increases in 88 inch engines with stock compression. We have been using it in many of the kits that we put together. That little cam is turning out to be a great perfomer!!1
ORIGINAL: HDWRENCH
Thanks for all of the replies!
lots of great suggestions, but I think I like what HDWRENCH is saying about the Andrews 54 cams...
