Sponsored by: Jekill and Hyde
Tuning Edelbrock QwiksilverII carbs
Old 05-03-2008, 05:57 PM
customsoftail200's Avatar
customsoftail200
customsoftail200 is offline
Default Tuning Edelbrock QwiksilverII carbs
Does anyone have any input or experience tuning these carbs? I just got a dual set up for my bike. Thanks
Old 05-03-2008, 08:06 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Default RE: Tuning Edelbrock QwiksilverII carbs
Good Luck....I had a customer that had a set of those, I found them VERY difficult to dial in....when you get the low end working the top would mess up and when you got the top end right the low end would be too rich. After the engine was dynoed I seen the power wasn't what it should have been so I installed a SE 44mm C/V carb and gained 22 hp and 17 tq. The Quicksilver carb and manifold was sent back and we where refunded the $850.00 they cost at the time. This was about 8 years ago, I don't know if the carb hasa better way of jetting or if it is still turning the needle to direct the flat spot toward the manifold side or air cleaner side. Any way good luck.
Old 05-03-2008, 08:27 PM
customsoftail200
I think that was with the original Qwiksilver, but supposedly the QwiksilverII is much better. I'm just about to put them on, but I don't have a manual or anything for them...
Old 05-03-2008, 11:34 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
http://www.cas4.com/Carburetors-Inta...wiksilver.htmlif this is what you have then like I said 'GoodLuck' They look good but they do not perform well and you will see also that your forearm will get pumped up from the carb return spring. Sorry to tell you this but if your not just into show....send them back....if your into the looks of theset ....nothing looks better, it has nice lines and a real mean readyness atitude to them.
Old 05-04-2008, 07:43 AM
wfolarry's Avatar
wfolarry
wfolarry is offline
All show....no go. Real PITA. They do lookgood though. The newer ones are better than the older ones but like Doc said if you want more power send them back.
Old 05-04-2008, 04:00 PM
customsoftail200
They're really that bad?? Well, it's all I got right now, so I'm going to have to make them work. They should be on the bike next weekend.
Old 05-05-2008, 05:38 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We have also witnessed the same as Doc and Larry.
One tough hombre to work with.
Seems you can never get 'em just right.
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 05-05-2008, 07:55 AM
customsoftail200
Is that with the Qwiksilver II? What's the difference between the Qwiksilver and Qwiksilver II??
Old 05-05-2008, 09:41 AM
Doc 1's Avatar
Doc 1
Doc 1 is offline
The Name....
Old 05-05-2008, 12:12 PM
HDWRENCH's Avatar
HDWRENCH
HDWRENCH is offline
I would second that, had a 107 inch evo here with two of them on the bike. [:@]You get one area tuned and the other is way off, you end up with a bike that will run really good in a small rpm range or just poor over all. And if you think one carb is hard to pull try two!!!! In the end I just told the customer what he had and that looks where the reason for the twin cabs on a huge manifold. Plus he had NOS that he wanted tuned in as well!!! He end up burning a set of pistons, Info given to him by quicksilver.
I am not sure if the QS carb is harder to tune or the holley two barrel toss up there. Way better ways to gain power than either of them. Good Luck with the carb.
Quick Reply: Tuning Edelbrock QwiksilverII carbs
