Lifters for TC88
Lifters for TC88
Hey Gang,
Waiting on parts to replace my cam and the cam tensioner unit. A gotta question for a couple remaining parts.
A little background...04 Fat Boy, 95ci, High Comp (10:1) cast pistons, 251 cam (replacing with Andrews 55N cams), heavy duty valve springs, adj pushrods, SE ICM.
I had SE lifters (tappets) installed in the above build with the above mods, done when the bike was new. The roller wheels on the lifters disintegrated and destroyed my cams...luckily no other damage. My indy said there were noted problems with these lifters.
Can you guys recommend some durable lifters for this cam job? I've heard about the new HD "B" lifters. Should I go with these lifters or some aftermarket alternative? What about the current SE lifters/tappets....any good? My indy said the current SE lifters are fine but not necessarily needed for this job. He said 'stock' lifters will do just fine. Are the current stock lifters the "B" lifter? Since HD SE lifters got me into this trouble in the first place, I just want to be sure that we install a good, proven lifter at this point. I don't know if this matters but the lift on my old 251 cams was .579.....the lift on the Andrews 55N cams is .550. Durations are about the same.
Also, I've read its a good idea to replace the inner cam bearing with a Torrington 148B. Is this the best way to go or is there another bearing alternative?. Where can I purchase this bearing?
Lastly....what is a Baisley Spring? Is this something I need for my cam job?
Appreciate the help...
Regards
Regards
the stock "B"lifters are fne.
Baisley Spring
Baisley spring is a spring that goes in the cam chest bottom port . you take out the original spring (very flimsy) and put the baisley one in. increases oil pressure....
inner cam bearings
your new cam should come with them.
if not give Scotty at hillside a call. i am sure he has them.
Baisley Spring
inner cam bearings
the cam set up should come with inner and outer bearings.
the ones that come with the cam are good
usually toringtons or another good company.
use them
the baisley spring call Dave at 1-610-297-0321 (JD.s cycleworks) tell him ya want to buy a spring and i am sure he will mail one to you
G
use them
G
The ONLY lifter we use/stock are the Harley lifters.
They are as good, and or better, than most out there. Never a problem.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Biker Bob
Exhaust System Topics
05-27-2011 09:02 AM
