SE 113" kit dynoed. Is something wrong?
Just dynoed Rocker with SE 113" kit including SE 110+ heads, SE-264cam, 50mm TB, SEST, heavy breather and V&H Indy 2 into 1 pipe.
Results: 117,5 rwhp and 119 ft-lb witch I think is normal for this kind of combo? BUT torque curve has quite big dip at 3-3,5K:
2500 - 100ftlb
3500 - 95ftlb
4500 - 119ftlb (max)
I think there is 10ftlb missing at 3.5K. AFR ratio is OK (about 13) all the way.
Any idea what could cause the dip? Pipe? Cam? Something else? I am sure SE did not plan this kit like this..
2500 - 100ftlb
3500 - 95ftlb
What pipe, and what is the ccp??
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Pipe is V&H Indy Competition series 2 to 1.
Link to pipe: http://www.vanceandhines.com/product...ompseries.html
What do you mean by ccp? Do not know the acronym.
Here in Finland there is not so much competence on SEST tuning. The AFR was first way too rich at 3-4K. We got that sorted out but it did not have any major effect to TQ curve dip. Sure it helped a bit.
It would be extremely intreresting to compare SEST map on some other SE 113" kitted bike.. With SEST base map (176NL-005) the dip was about 4ft-lb worse than it is now afer tune. VE tables where altered about 7-10 units down at 3-4K and on 40-100 throttle positions. From 4 to 5.5K VE tables where moved about 5 units up. Some minor changes was also done to AFR-map. Other than that SEST map is quite stock. Iddle richment by AFR table was also done.
Do you guys feel that is all about SEST tune to cure this? I am starting to think that combo with 50mm tb, V&H 2" tubes and SE-264 is not so good match at 3,5..
If someone has 113" kitted bike with SEST and somewhat close parts combination I would be more than happy to exchange maps and compare them...
EDIT: SEST map number
