Cams for 2010 96Ci Fatboy
Hello lads,
So I was about to order a set of T555 Torqster cams from TMan and someone said I should have a look at the Andrews Cams first.
There is a new cam I see - The Andrews 57H
So - I am looking for opinions on the two cams above, or any others you think are what I am looking for.
Basically I ride below 5000rpm - one up, and weigh 140lb ringing wet. LOL!
Thanks guys
Mongrel
Thanks guys
Mongrel
If you are considering pulling the heads and increasing compression, the 555T would be pretty strong at 10:1.
In all cases, you need a good pipe, tuner and good tune.
Hi Lads,
The plan is to do cams now, then head work later, so I want a cam that will allow me to progress.
I am going to go with the 57h. If it's crap, I can always swap it out.
Still... if anyone drops in here that is running this new cam in a 96, I would love to hear from you.
Cheers
Mongrel
Cheers
Mongrel
Hi Lads,
Cheers
Mongrel
Cheers
Mongrel
