Sponsored by: Jekill and Hyde
2003 road king compensator nut 5,500k
Old 11-12-2012, 01:12 PM
ZOEY's Avatar
ZOEY
ZOEY is offline
5th Gear
Default 2003 road king compensator nut 5,500k
My 2003 road king with 5,500 miles compensator nut coming off. Harley says 75 foot pounds of torque then 45 degrees from there. I checked with torque wrench and ended up with 235 foot pounds. That is a lot more than the factory 165 max. I still think I should have ran my marks clear over to the inter primary. I am not positive that the compensator might have moved. Anyone else ever check their torque after this new method of tightening? That is a lot of torque on that spindle nut and crankshaft!
Old 11-12-2012, 08:15 PM
djl's Avatar
djl
djl is offline
Received 2,031 Likes on 1,499 Posts
Compensator nut torque is 150-165 foot pounds; no 45* extra torque, that's the trans pulley torque method. If your compensator nut is the issue and comes loose, remove it and shave .030" of the end. This was a common ailment with the early models. You could torque the nut to spec but not achieve the clamping pressure to keep the assembly tight. The MoCo offers some shims that fit behind the comp nut to address the issue but before shims were available, the problem was solved by shaving a bit off the end of the comp nut. It must be done by a machinist and with the right equipment to keep the end of the comp nut square.
Old 11-12-2012, 08:44 PM
BVBOB's Avatar
BVBOB
BVBOB is offline
You can use a washer under the comp nut part number (PN 24033-70)
Old 11-12-2012, 11:26 PM
ZOEY's Avatar
ZOEY
ZOEY is offline
5th Gear
I did use washer pn 24033-70. FYI M-1170 service bulletin is what I used. I can find no info on the trans pulley torque method.
Old 11-13-2012, 07:31 AM
ZOEY's Avatar
ZOEY
ZOEY is offline
5th Gear
Old 11-13-2012, 07:32 AM
ZOEY's Avatar
ZOEY
ZOEY is offline
5th Gear
Old 11-13-2012, 08:08 AM
dynaratt's Avatar
dynaratt
dynaratt is offline
The C/N on my 01 E Glide came loose just before I bought it. Had about 40K miles on it. I did some diggin and found a TSB that in essence puts the nut at 240ish ftlbs when you follow the HD procedure. If I recall the original spec was 175 ftlbs not 75 as mentioned before the additional turn.
Old 11-13-2012, 08:19 AM
ZOEY's Avatar
ZOEY
ZOEY is offline
5th Gear
dynaratt, did you have any more problems with the c/n after that? I tell you 230lbs+ worries me, but I can't imagine that nut coming loose after that. If the threads don't pull out.
Old 11-13-2012, 12:14 PM
djl's Avatar
djl
djl is offline
I stand corrected on the 45* procedure for 2993-2005 models. Have had the comp nut on and off my 2002 FLHT many times, torqued to 165 ft.lb per manual, hipo engine, ridden hard and it has never come loose. However, the nut has been shortened by .030".
I would bet a six pack that if you shave the comp nut and torque to 175 ft.lb. with a drop or two of red, it will not come loose.
Old 11-13-2012, 12:42 PM
ZOEY's Avatar
ZOEY
ZOEY is offline
5th Gear
djl. Good Call! This winter I will prolly tear into it again and keep the washer on the spindle nut and tighten it to 175. Now it is at 235lbs makes me nervous, in fear of stripping the threads off! I already bought another new spindle nut with the patch, I will add 3 drops of red locktight to it also. $10.00 from Harley gets you a new spindle nut. Bought a primary gasket today cost $30.00, I thought it should be the other way around. Thanks for the post.
Quick Reply: 2003 road king compensator nut 5,500k
