Front Wheel Axle Bearing Spacers - Sportster
I'm in the process of installing a 19" cast wheel, from an 05 Low, on my 04 1200C. The wheel hub width is narrower than that of the 21" laced wheel from the C model. The C model uses a 1/2" spacer on the left side and a 1/8" spacer on the right. It appears that the 19" cast wheel will need a 1/2" spacer on the right and maybe a 5/8" spacer on the left, but I am not sure.
Does anyone out there have a parts manual that can give me the correct P/N's for the required spacers.
Thanks
Thanks
RE: Front Wheel Axle Bearing Spacers - Sportster
Do a mock up with the wheel centered and use the spacers you have to wotk with that are too narrow.Measure to what you need for length(use caliper) add it to your existing spacers length and there you go.You may find some that fit the bill ,or buy over a little and get them turned to the proper length.Toby
