Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
engine only starts in neutral
Old 08-13-2009, 04:15 PM
locokk's Avatar
locokk
locokk is offline
Stage I
Default engine only starts in neutral
I have a 2008 road king classic. When i first purchase the bike if i was on the road and i stall i was able to start the engine in any gear by just pulling the clutch, then i changed my handlebars and after that if i ever stall i have to look for neutral for the bike to start. The bike only starts in neutral now. What do you guys think my problem is? is it something i did on the handlebar? Please Help!!!!!
Old 08-13-2009, 06:39 PM
ghostrider69's Avatar
ghostrider69
ghostrider69 is offline
If it has one it sounds like a problem with the clutch safety switch that is behind the clutch lever. Did you wire it back up when you changed out the bars? If it has one you can see it just by looking right on the backside of the lever. Double check your install to make sure the wires are not cut and that they are plugged in completely.
nikman
05-24-2019 12:53 PM
Lemarchand98
09-22-2016 02:06 PM
oliverwide
06-27-2016 02:01 PM
VaThumper
01-27-2011 11:08 AM
Bat
09-10-2010 10:49 AM
Quick Reply: engine only starts in neutral
