Bike won't start unless in Neutral
Old Jan 27, 2011 | 09:41 AM
VaThumper's Avatar
VaThumper
Default Bike won't start unless in Neutral
Help, I can't start my 2010 TriGlide unless bike in out of gear. have adjusted clutch all the way in and out.
Thanks
Old Jan 27, 2011 | 10:03 AM
slothy's Avatar
slothy
check clutch switch on lever perch
Old Jan 27, 2011 | 10:50 AM
wkl2546's Avatar
wkl2546
Like SLOTHY said...inside the clutch lever housing, there's a "clutch interlock/overide"
switch; IF the bike is in gear, you must pull in the clutch lever before it will start....
if the bike is in Neutral, there's no need to pull in the clutch lever.....
Old Jan 27, 2011 | 10:58 AM
highwayman1224's Avatar
highwayman1224
If you just switched levers, that might be it too. My 07 will only start in neutral because the levers are pre 06.
Old Jan 27, 2011 | 11:03 AM
VaThumper's Avatar
VaThumper
Thanks Put washer (glued) on back of lever and it now contacts switch
Old Jan 27, 2011 | 11:08 AM
soft 02's Avatar
soft 02
What they said!
tigerwiles
VRSC Models
19
Jan 15, 2019 04:46 AM
rogersachs
Feb 20, 2014 12:17 PM
Bat
Sep 10, 2010 10:49 AM
rome304
Aug 6, 2009 05:59 PM
CLL375
Aug 14, 2006 04:25 PM
