Frame/Suspension/Front End/Brakes Discussions for your ride comfort and braking power.
big problems bleading
Old 12-21-2006, 02:00 AM
HDWG's Avatar
HDWG
HDWG is offline
Big Kahuna HDF Member
Default RE: big problems bleading
Had the same troubles last summer. Turned out the bleeder valve was bad
Old 12-21-2006, 04:39 PM
thrillseeker's Avatar
thrillseeker
thrillseeker is offline
I had to pump my master cylynder about 200 times before it finally started pushing fluid down into the line
Old 05-26-2015, 05:54 AM
Kayakeur's Avatar
Kayakeur
Kayakeur is offline
Location: Eastern foothills of Shenandoah Mountains, Virginia
Have stroked rear pedal over 1,200 times 4 different days. Most strokes get tiny bubbles coming out the speedbleeder.
XL883C 2005 Replaced rear master cylinder, added new DOT 5 and a SpeedBleeder.
Lots of tiny bubbles on most strokes, a few bubbles 1/8th inch. Varied strokes, mostly full stroke to bottom, slow, fast, partial slow strokes. No leaks. Bike vertical.
Speedbleeder.I've never had brakes bleed like this. I was pumping so much new fluid that I routed the bleed tube to the reservoir. (I bled the front brake fluid no problem.) No Joy. What to do?
Kayakeur Bud May 26-2015
Old 05-26-2015, 08:32 AM
JohnMB's Avatar
JohnMB
JohnMB is offline
the master cylinder has to be perfectly level to bleed.
Old 05-27-2015, 12:12 PM
Kayakeur's Avatar
Kayakeur
Kayakeur is offline
Bleeding: Why is it not good to push the pedal all the way down?
das56170
EVO
24
10-30-2023 07:53 PM
Redbeard07
Shovelhead
04-24-2018 08:54 AM
Jshipley90
10-20-2013 09:37 AM
apehanger65
03-29-2013 09:55 AM
wico1
07-09-2007 11:03 PM
Quick Reply: big problems bleading
