Fork Oil Change
Fork Oil Change
The manual calls for 395cc of fork oil to refill the forks on my '07 FLSTN. Just how precise must one be? What could be the consequences of adding too much/little to one or both forks? FWIW, I've only done a fork oil change once in recent years, and that was not on this bike.
Received 4,317 Likes
I don't know what you mean(?) The 395cc is the amount required in each fork when the forks are left in the frame, not disassembled.
I drained the oil into a measuring cup (don't tell my wife) and replaced it with the same amount I took out.
Wet = the amount needed to fill forks that haven't been dissembled.
I use a baby bottle to measure the fork fluid I put in mine.
Received 4,155 Likes
A kitchen measuring cup is plenty accurate for such things (as was said-just don't let your wife find out, or buy your own and keep it in the garage).
your right about using 395cc or 13.4 ozs.... our 07 bikes (FLs) use the same amount.
When I had my INDY change out my fork oil 2 yrs ago they only put 11 1/2ozs (What the FX Softails use) back in and the front end was really soft and Clunked hard on rebounds...
I called him as soon as I got home after leaving his shop and told him what the bike was doing and asked how much they put in.. I took my manual so show him it should have had 13.4 added back.
He just added 2 ozs more to each side.... then all was well and fine....
So try to be as accurate as you can be...
