Best Cam to Benefit Current Dyno Sheet
Old 12-12-2014, 04:55 PM
Shaved Ice's Avatar
Shaved Ice
Shaved Ice is offline
Default Best Cam to Benefit Current Dyno Sheet
I am looking for input from the cam gurus. My current Dyno sheet is attached. 2013 Fatbob 103, SE intake, SE tuner, V&H 2-1 Competition Series. What cams would best accent my current torque band?
Old 12-13-2014, 12:45 PM
nhrider1's Avatar
nhrider1
nhrider1 is offline
If it's torque you're looking for try Andrews 48's. Great torque cams.
Search the web for dyno runs with the 48's. I tried to post a link to another forum, but apparently that's not allowed.
Last edited by nhrider1; 12-13-2014 at 12:48 PM. Reason: Deleted link to another forum.
Old 12-13-2014, 12:56 PM
smokindownthehwy's Avatar
smokindownthehwy
smokindownthehwy is offline
While I don't have experience with motorcycle cams I'd recommend you contact Comp Cams that will custom grind any cam based upon your engine at no extra charge. They already produce Evo cams for Harley Davidson.
I have used Comp Cams for automotive race engines and their expertise is unmatched IMHO. You tell them what you have and they will provide the correct cam for your individual application.
http://www.compperformancegroupstore...egory_Code=EVO
If you do contact them then I'd like to hear how everything turns out.
Old 12-13-2014, 01:09 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
I think it will be hard to get a lot of torque out of those pipes. They will most likely show a big torque dip in the lower rpms then at about 3000 to 3500 tq and hp will look better. So do you want to pick cams to compliment the pipes or pick cams that try to overcome the pipes?
Old 12-13-2014, 02:35 PM
Tn.Heritage's Avatar
Tn.Heritage
Tn.Heritage is offline
I'll agree on the exhaust, you'd be better with a black 2-n-1 like a fat-cat or a good rush exhaust. On the cam side if you have a 103 engine put a Andrews 57 in there and watch the tq climb.
Old 12-13-2014, 03:09 PM
Crazy's Avatar
Crazy
Crazy is offline
Received 1,539 Likes on 809 Posts
Here's my dyno run after tuning with 48's in a 96" engine, intake, and V&H slipons on my stock headers. Nice drivability with these cams.
Old 12-14-2014, 01:04 AM
Next In Line's Avatar
Next In Line
Next In Line is offline
Old 12-14-2014, 07:10 AM
nhrider1's Avatar
nhrider1
nhrider1 is offline
I have to agree. Those pipes aren't going to help your torque curve much.
peg20
09-29-2015 07:18 PM
bigzig89
03-28-2013 12:17 AM
thewholehog
Exhaust System Topics
19
02-09-2013 06:57 AM
crazyanimal
08-16-2012 09:26 AM
mike_oh
12-31-2007 01:35 PM
Quick Reply: Best Cam to Benefit Current Dyno Sheet
