Vista cruise control
Found some old posts but nothing that really answered my question. I was looking for a cheap throttle lock only for long flat trips and picked up a vista. For you guys using them does your throttle flip back to closed position while the vista is installed? Even when the vista is in the open position, my throttle will not snap back to closed. I'm not really sure if this is a problem or not being that the throttle is still very loose and easy to manually close. I would just think that while the vista was in the oen position, the throttle would not be so tight that it wouldnt snap back. Like I said I'm only using it for short periods of time on long trips so its probably not that big of a deal but thought I would ask. Also there is an adjustment screw but I have that as loose as possible already.
Received 8,249 Likes
I had the vista on my Sporty and the throttle was not as "snappy" as it was without the vista installed. But the throttle did not have any bind or stickiness to it. I found for the lock to be effective, it had to be adjusted fairly snug, which did limit the snap back of the throttle. I did find that 99% of the time I manually operated the throttle with no issues, and would consider using this again if I did not have cruise. I sometime wonder if the other style throttle lock (they type that replaced the factory throttle lock, but was quarter turn) might be a better alternative.
Throttle Lock
I had one of these for a while on my Dyna...
http://www.ebay.com/itm/THROTTLE-LOC...9acef4&vxp=mtr
The problem that I had with it was that there was always tension on the throttle, so if I wanted to open more or close it more, it took more effort than normal. It gave me hand cramps so off it came.
Received 14,173 Likes
With the paddle, the throttle is held in position with the part of your hand closer to your wrist, so you aren't really holding it with your hand muscles. I recently made this change to my 95 Heritage and it is a world of difference. In essence, your hand is just resting in position.
Loosen your "star wheel" some, or pretty much all the way. It is most likely the little nut is too tight. The one that is on the side. It doesn't need to be tight at all, just enough that it won't fall off. The one I'm talking about holds the lever on. I had one and did the exact same thing.
I have tried the paddle thing and it doesn't quite do the job. Sometimes you need to get your hand off the grip and just shake the dang thing out.
Let us know if that does the trick or not.
