Thoughts on Progressive suspension
OK Guys, here goes, I'm considering replacing my shocks with 11.5 inch progressives - any and all suggestions will be considered. Please explain why you think that your choice would be the best. Thanks for your input. I will give consideration to all comments in consultation with my mechanical guru. Thanks for your time and input, I will post on HDForums my ultimate choice and my reasons why.
FYI, I am 71 Y.O. 134 lbs and 5'6" and my ride is a 2009 XL883L.
Ride Safe - Ride Smart
"He Who Lives In Joy Does his Creator's Will".
The Baal Shem Tov, Founder of Chasidic Judaism... ca. 1750's
At your size and weight I cannot believe your bottoming out the stock shocks. I had progressives on my sporty, but heavier than you and sometimes rode 2 up.
I wouldn't change unless you really are having major ride issues.
Received 5,388 Likes
I had Progressive shocks and fork springs on/in my Dyna Superglide. Made the bike ride like a buckboard. Removed them that day. Ebayed the shocks and the fork springs are still hanging up on my peg board in the garage. Want 'em, they're yours.
Oh yeah, I weigh about 100lbs more than you...
EDIT~ If you are lowering your motorcycle, you may need to get a shorter "jiffy" stand....
and reduced cornering clearance...
Did you order the standard or heavy duty? Stock length, or longer? Did you have the preload set at minimum and they still rode hard?
What didn't you like about the front springs?
"He Who Lives In Joy Does His Creator's Will".
The Baal Shem Tov, Founder of Chssidic Judaism... ca. 1750's
Ok, I've owned two Sportsters. Absolutely love 'em.
Here's the part about "mods" I don't understand. We all love Harleys because they're Harleys. The two knocks on Harleys that are pretty much not up for argument, (at least compared to real "performance" motorcycles) are poor brakes and shitty suspension. The worst part of the "shitty suspension" part? The fact that a typical Harley rear shock might have a travel in the 2" range.
And then owners want to lower them. Whaaaaa?!? What's 2" minus 1"? So, you either bottom out running over a painted line on the pavement, or you set it so stiff that your vision blurs at over 27 mph.
My Super Glide has stock 12" rears. I'm trying to decide between 13", 13.5", or 14". I can probably keep the stock jiffy stand with the 13", any longer and I'll probably need a longer stand to keep it from falling over. They won't bottom out, though.
Also, an acquaintance is a licensed AMA flat track racer and a professional SuperMoto/SuperMotard racer. He's really pushing me to get the 14" because he knows I like to ride. And, he says the handling will be dramatically improved over stock, because the increased rear height will reduce the front rake and trail slightly, which will make it want to turn in better in the curves.
Shorter than stock makes all the bad things happen.
+1 When I had my Sportster I switched out the stock shocks for 12.5" progressives, greatly improved the ride.. You could actually tell it had shocks on it after the switch..... I'm running 12" progressives on my Dyna,again, much better than stock..
12" Progressive 412's on my Shovel. Rides over bumps nicer than my bagger.
Then again...that's a totally different bike. Much heavier.
