Front O2 sensor
08-21-2015, 08:12 PM
Front O2 sensor
Well the O2 plug came out and the threads are messed up and flatten. I haven't checked to see if the threads on the pipe are messed up also. Are they strong enough to not strip like the O2?
08-21-2015, 08:16 PM
The sensor is going to have the weaker threads. You should be ok, if not get a tap and die from harbor freight to fix. Though I doubt you'll need it.
08-22-2015, 08:45 AM
08-22-2015, 11:40 AM
Front O2 sensor
If it is the sensor that's buggered up and it's one of the larger 2 wire sensors, I have 2 extras I aquired with some other parts and can't use. Your welcome to have them if you need them.
Shoot me a message if you need them.
Doug
08-22-2015, 01:17 PM
Using tools from Harbor Freight is just asking for problems.
08-22-2015, 02:27 PM
Quote:
Originally Posted by
Next In Line
this is what i was thinking wheni was reading the above post. most Harbor Freight stuff is junk. ok place for sandpaper and maybe throwaway stuff.
08-22-2015, 08:05 PM
I suggested harbor freight because it sounded like a one time use for this application. If you regularly do this obviously don't buy harbor freight.
Fast Fac
09-13-2011 09:38 AM
UT-rckr
06-29-2011 10:54 AM
young n bag'n
01-01-2011 05:37 PM
Dango
12-23-2009 10:29 AM
timberwolfz28
08-09-2008 09:14 AM
