My 2006 Ultra will not fire on rear Cylinder
Old 09-08-2015, 12:30 PM
blrobbins3's Avatar
blrobbins3
blrobbins3 is offline
Stage III
Exclamation My 2006 Ultra will not fire on rear Cylinder
Had bike serviced (40,000 mile) took it to the coast here in Mississippi ,ran perfect on the way down.. Rode about 120 miles.. On the way back it started cutting out.. Check engine light came on ran bad ,check eng light went off ran perfect , check eng light came back on ran bad.. Back and forth with the eng light.. Got worse and worse.. Finally got to where it only ran on one cylinder for the last 30 miles.. Ran diagnostics through the odometer.. Code P1355 and P1356.. Bought a new HD coil from dealer.. Still no run on rear cylinder... Another forum they said Crank position Sensor so I went to Harley and bought one.. It does fire every once and a while (spits and sputters).. Took a timing light on the wires and rear is erratic it sparks every once in a while.. The front cylinder never misses a beat.. Un-rideable... Need Help !!!!!! I have had lots of comments about fuel and compression... It IS NOT FUEL Or Compression.!!!!. There is almost no spark ( It sparks fine on start up) after it runs for about a min.. It is like it is in Limp Home mode..
Old 09-08-2015, 12:39 PM
Crimson's Avatar
Crimson
Crimson is offline
Have you checked fuel or compression?
(Backs away slowly)
Old 09-08-2015, 02:23 PM
blrobbins3's Avatar
blrobbins3
Stage III
(Backs away slowly)
It is not fuel or compression !!! It is lack of spark....
Old 09-08-2015, 03:05 PM
big cahuna's Avatar
big cahuna
big cahuna is offline
Can you try a different plug wire, or try swapping them to see if the wires bad.,,
Old 09-08-2015, 03:36 PM
blrobbins3's Avatar
blrobbins3
Stage III
New wires.. 2 sets of new plugs ,New coil, New crank sensor...
Old 09-08-2015, 04:21 PM
kojak's Avatar
kojak
kojak is offline
Received 2,494 Likes on 1,244 Posts
Most of the time when I hear about P1356, it ends up being a hole in the fuel line inside the tank. Check it out.
Old 09-08-2015, 04:33 PM
hogcowboy's Avatar
hogcowboy
hogcowboy is offline
My 07 did the exact thing last year. It ran on one cylinder wide open for 80 miles getting me home. I'm the worlds worst on electrical issues so the dealer got it. They looked for a short but found none. They final spotted one wire that was very tight that was being pulled by a wire zip tie thing. They cut the tie, disconnected and reconnected everything around it, plus a little rerouting of that wire. Added a new zip tie and it's work perfect ever since. Exactly which wire they did that to I don't know. But I'd check and recheck every connection you can find in there. Cost me $50 but they worked at it for 2 days off and on. So it was money well spent for me. But I admit I was not sure they fixed anything. That's been over a year ago and over 10k miles so I guess they did. Check your wire connections. Especially looking for a tight one.
Old 09-08-2015, 08:00 PM
Bill03E's Avatar
Bill03E
Bill03E is offline
It is probably the wire going to the rear injector, they are tight (too short) from the factory, though that doesn't count for why the spark is erratic.
Old 09-09-2015, 10:33 AM
Ironcleveland's Avatar
Ironcleveland
Ironcleveland is offline
1355- rear ignition coil high/shorted. Either a bad coil or the wired going to it is shorting out somewhere. Look for a chafed wire.
Papa Georgio
04-21-2023 02:01 AM
harleyman6971
09-08-2013 03:31 PM
lonelyrider1966
09-03-2013 07:49 PM
sparky_mo
09-12-2009 08:15 AM
flaw42
Exhaust System Topics
08-08-2007 12:39 PM
Quick Reply: My 2006 Ultra will not fire on rear Cylinder
