stuck throttle(grip)
Several months ago I replaced the grips on my Sportster. There were no problems. A few days ago I removed the top of the piece that holds the throttle(grip) so I could lube the throttle cables. Again no problems.
But when I put the cover back on, the grip tightens up and won't move, or at least 'drags', when I tighten down the cover. Is there a trick to putting the cover back on, that I somehow stumbled on when I changed the grips, that would prevent the throttle(grip) from turning?
Thanks
Thanks
It's a finesse move to get it back in there right.
I'm not used to my problems being so simply solved.
Problem solved! I don't know how it happened, but somehow removing the two screws holding the cover on, lifting up the edges enough to squirt some cable lube into the top of the cables, and then retightening the cover somehow changed the setting on the 'thumb screw'. Thanks everyone!
