Air shocks question
Air shocks question
I posted this in the Dyna section but afterwards I thought I would probably get more traffic in here... so here's my question. I am thinking of running a set of the touring bike 13" air shocks on my 07 Street Bob. Could I eliminate the plastic air lines and just put Schrader valves in each shock? Then I could just pump each shock individually to whatever PSI I need. If this would work, what is involved with doing it? Are the shocks threaded for this and is it as simple as just buying some valves and screwing them in?
http://www.oreillyauto.com/site/c/de...keyword=15-593
You don't need anything just bolt them up. I ran higher PSI without changing shock oil for the last few years. I just never got to changing the oil. Here are the NAPA schrader valves.
SHORT NTH 90294 (90-294)
LONG NTH 90290 (90-290)
Make sure the shocks are upright before you disconnect the stock plastic lines.
