I have used S-100 for the same oil drip you are talking about and it worked fine as long as its a small amount of oil. If there was a lot of oil I would use something else.
Never thought of using brake cleaner, but wouldn't that harm your motor mount if it gets on the rubber?
I used S-100 on my progressive 970 shock and it turned the gloss black spring to a flat black. F'k. It was the first time I used it on my shocks, never had a problem using it before
Did you give it a good rinse? If you don't use a strong steady stream to rinse that sh*t off it will leave a residue on the surface
