RoadKing Classic to ride like street glide
I think the only real difference is the shorter shocks on the rear - I'd think you would be able to find a good deal on some take offs somewhere. Or you could probably just install a shorter aftermarket pair, but for decent ones it'll get pricey.
Keep in mind that when you take away that extra inch of travel, your ride quality is gonna suffer. Noticeably.
I guess you could lower the rear with the shorter rear shocks, put a larger wheel and a low profile tire on the front, & I suppose a different seat, but I doubt just doing that will make you feel like you're sitting "in" the bike. It would be a good looking bike that still has a nice comfy ride though! Touring frames are designed with a higher Center of Gravity and that doesn't change much by lowering the whole bike. The weight ratio is still going to feel top heavy because, well, it is.
To get "in" the bike, the first mod you should do is to your seat. You can have the stock foam removed and have some memory foam put in. The ride quality will improve, it will sit you lower (Call C&C or mean City Cycles), and it is probably the least expensive mod you can do. I would start there.
My last bike was a street glide. I thought the stock air shocks were horrible. I replaced them with Progressive 944's. They give the travel of a 13' shock in a 12' housing. Don't ask me how, I don't know. But I do know the ride was significantly improved. BUT that mod will cost you some $$.
Good luck and keep us posted.
This^
Seat can make a huge difference in the feel/look of the bike. The seat on my RK sits me back more and gives me a more stretched out,laid back feeling than the stock "upright" seating it came with or like on my Ultra.
I have been running lowered shocks on mine for about 2 years, like the look but not the ride. I will soon be going with Progressive or something similar.
Find some street glide shocks used. Check out the part numbers in the link.
https://www.hdforums.com/forum/sport...nd-length.html
I have shorter rears on my RKC. Also a C&C seat, really makes me feel in the bike.
