Electrical Problem
Old 04-28-2016, 05:26 PM
Lowell64's Avatar
Lowell64
Lowell64 is offline
Stage III
Default Electrical Problem
I have a 2012 Street Glide and more and more frequently my check engine and voltage lights come in when I ride. They don't come on all the time and sometimes go out after a few minutes. My voltage gage does drop to around 11 volts. I suspect the voltage regulator. Any advice will be appreciated.
Old 04-28-2016, 05:27 PM
jdw1's Avatar
jdw1
jdw1 is offline
I think you have it figured out already!
Lowell64 (04-28-2016)
Old 04-28-2016, 05:36 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,220 Likes on 1,622 Posts
Before digging into the electrical, try checking the battery cable connections...both ends...for security/corrosion.
Lowell64 (04-30-2016)
Old 04-28-2016, 05:59 PM
Jackpot Johnnie's Avatar
Jackpot Johnnie
Jackpot Johnnie is offline
I was getting a number of diagnostic codes popping up on my Road King. Crank Position sensor code, high voltage code. Replaced voltage regulator and everything is back to normal.
Old 04-30-2016, 05:36 PM
Lowell64's Avatar
Lowell64
Lowell64 is offline
Stage III
Thanks to all. I just finished my test ride and all my problems are gone. The voltage regulator worked great.
PennStateJeff
09-25-2022 08:39 AM
techmanrod
10-16-2019 04:29 PM
kevjo
09-10-2018 06:51 PM
Bluraven
Electrical/Lighting/Alarm
10-06-2016 07:53 PM
pt4u2nv
05-23-2014 08:50 AM
Quick Reply: Electrical Problem
