Bad voltage regulator
I thought that perhaps I'd post this on this forum as well since the issue is related to electrical.
2009 Heritage.
My voltage gauge which typically stays right at 14vdc suddenly jumped to 16vdc (max on the gauge) and then dropped down to 12vdc.
I also got both the battery and check engine lights, however they extinguished after a brief period.
Once the bike was parked for a while (I'm guessing cooling off) everything seemed back to normal for about 10-15 minutes in operation then the voltage fluctuation started again along with the battery and check engine lights.
I got ECM codes P0562 (under voltage), P0563 (over voltage) and Speedometer codes P1006 and P1007 (not sure what those relate too, perhaps the battery and check lights).
I checked the voltage at the battery and it seemed normal at around 12.8vdc with everything off, 9.8vdc while starting, and 13.96vdc at idle.
I could never get it to fail while being able to test the voltage with my multi-meter.
I checked the 3 outputs of the stator and all three were open to ground which apparently means it's reading good.
My gut was telling me that my problem was a flaky stator but since I wasn't prepared to tear into the engine to get to the stator I decided to order a new voltage regulator.
From my research Cycle Electric regulators seem to have really good reviews and I found one on e-Bay for $129.00 so I pulled the trigger.
I got the new regulator in today and immediately installed it.
I went on a 50 mile city/hwy ride and my voltage stayed right at 14vdc and never wavered so apparently my problem was in fact the voltage regulator.
Also I swear it seems I've got more power but I don't see how a voltage regulator would have an effect on power.
Anyway, hopefully my problem is fixed.
I have a Cycle Electric, they are popular. There design sounds better. But I can't say if it really makes a difference or not.
