Voltage regulator
Old Sep 9, 2018 | 06:23 PM
kevjo's Avatar
kevjo
Default Voltage regulator
My 07 Custom's check engine and battery light came on while riding today. I checked the code and it came up voltage regulator. My question is, would it be okay to ride it to my local indy to have them check it out? Bike runs fine and i just changed the battery. Thanks for any input.
Old Sep 9, 2018 | 06:59 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You'll be able to ride it as far as the battery's charge will allow you to. Once it's depleted, you're going to be on the side of the road with a cellphone in your hand.
Old Sep 10, 2018 | 06:48 AM
kenny55's Avatar
kenny55
The VR fault may be low voltage or high voltage. Measure the voltage at the battery if you can with the bike running. If its too high, like higher than 15 volts, you could damage your new battery by overcharging it. It should read about 14 volts. I think a diagnostic fault appears at 16v.
Old Sep 10, 2018 | 09:36 AM
chrisj49's Avatar
chrisj49
I don't know how it could know it's the regulator if the voltage was low. If the code is just the voltage level, it's not a VR code and you can't assume the VR is the problem. In a low voltage issue, you have to eliminate the stator before moving to the VR. If the voltage is too high, it points to the regulator.
Old Sep 10, 2018 | 03:26 PM
Andy77521's Avatar
Andy77521
this...
happened to me without warning, bike had the chrome cover over the VR, it overheated and left us on side of the road between Beaumont and Houston
Old Sep 10, 2018 | 06:51 PM
Bluraven's Avatar
Bluraven
Just replace the regulator with a Cycle Electrics.
If it fixes your problem they you’ll save a Dealer service charge and you’ll have the best aftermarket regulator.
If it doesn’t fix your problem at least you’ll have the best aftermarket regulator.
lefty33
Electrical/Lighting/Alarm
Mar 24, 2018 10:41 AM
jonmerrill
Dec 27, 2015 04:19 PM
QehQeh
Dec 26, 2013 05:41 PM
dunderwood
Jul 30, 2011 09:54 PM
TravelingBiker
Oct 12, 2009 09:41 AM
