Exhaust Flange Question
Hey All,
Recently installed my V&H Big Shots on my '15 Street Bob this past weekend. I made a thread about it and got some help throughout out the process. One thing that came up was whether or not the flanges need to fit flush and tight to the actual engine. I have about an 1/8" gap in between the flange and the engine at the exhaust port. I was told its normal with a good explanation, but after doing research on this site it seems there are varying opinions on the subject.
So which is it, do the flanges need to be snug and flush up against the engine, or is a small gap OK? Does it vary on pipes, gaskets, etc?
I have seen them both ways. Most of it will depend on the gasket you use, ie. the stock conical gasket or the SE flat gasket, or even say a James copper clad gasket. Some folks will stack 2 of the SE flat gaskets to get a seal. My preference would be to have a little gap between the flange and head with the nuts torqued properly. This way you should have a good seal with a little room to retorque after a couple of heat cycles. With the flange up against the head you may not get a good seal, or in fact the nuts may have been over tightened. Just my .02.
Have to agree with above responders. Although after-market pipe designs will vary, mounting procedure pretty much as OEM ~ slight gap between flange and head after proper torque. Can't tell in my pic, but there is actually about the same 1/8" space between flange and head on my FB pipes as your Big Shots.
Here is the link... scroll down someone has thunderheaders with the flange completely flush.
https://www.hdforums.com/forum/dyna-...ic-inside.html
Good to know its not really supposed to be flush and that it varies. I used the gaskets that came with the pipes. They are not the larger OEM ones though.
Received 19,926 Likes
Hey All,
