Any tips on front fork service
Received 5,388 Likes
Do you have the correct tools?
You have a manual and that's a GREAT Start.
Are you doing it because of mileage, handling, or just because?
Short cut - follow the manual to access top tube nuts
Remove the nuts and then drain the forks (catch all the fluid - measure it) and the refill the exact amount. This works in a perfect world.
Your world is not perfect and either you don't have the correct fluid level, and or your springs are lowered or too short.
That being said follow the service manual and do it correctly no point in putting effort into it only to do it again.
If I had the issue you did I would also completely rebuild them, not just service.
Tools???? There is a special alignment tool to remove the ignition - makes it much easier
Do you have a wrench large enough to remove the top cap?
Bench vice with some sort of jaw or soft material to protect the slider?
