flhx rear wiring harness question
Old 11-30-2007, 01:25 PM
jcog07flhx's Avatar
jcog07flhx
jcog07flhx is offline
Default flhx rear wiring harness question
I am adding a king tour pack to my 07 street glide and figured out that the lower fender light is plugged into the wiring harness where the tour pack lights are suppose to go. Any suggestions on adding another plug for the lower fender light so I can have break lights on my king pack? I know I can wire it into the tail light but I want it to be professional not some junky splice.
Old 11-30-2007, 01:44 PM
rh8234's Avatar
rh8234
rh8234 is offline
Default RE: flhx rear wiring harness question
I was just messing with the tourpak wiring on my Ultra last evening. The wiring going into the tourpak does not come from the 8 place connector on top of the rear fender (under the seat), but is a separate harness running along the top left side of the frame and enters the tourpak at the left front corner. I'm not sure where exactly it comes from, but if you have the service manual and parts manual, you should be able to look at the wiring diagram and figure out what harness and conectors you can buy to replicate the wiring inside the tourpak
Old 11-30-2007, 01:51 PM
jcog07flhx's Avatar
jcog07flhx
yep that is where they plugged the fender light. I took it out and plugged it into the tour pac and all the lights worked like they are suppose to,,,, unless i am misunderstanding. I will look at my manual but was quite sure that was it,,, thanks,,,, i will look again.
Runningblind924
Electrical/Lighting/Alarm
04-08-2018 08:42 AM
MikeBel
04-01-2015 03:41 PM
Jukebox
10-13-2009 05:41 PM
07yellowglide
08-09-2009 05:45 PM
pablo
03-14-2008 08:16 PM
Quick Reply: flhx rear wiring harness question
