Engine sputtering, 07 FLHT
Old 07-09-2009, 12:56 AM
OldpanRay's Avatar
OldpanRay
OldpanRay is offline
1st Gear
Default Engine sputtering, 07 FLHT
Having a problem with my '07 FLHT sputtering at low RPMs. On takeoff at lights and such. Intermittent cough or may be losing one cylinder. Also idle seems to fluctuate. Bike is very early '07, (July), was told it does NOT have the program that drops out rear cylinder. Revving engine seems to help, acts like what we used to call "carb loading up". 35xxx miles, but has been doing this for 20xxx. Fuel filter change didn't help. Still under warranty, just wanted to know if anyone else has had the same problem before I take it in.
Old 07-09-2009, 09:03 AM
FastHoss's Avatar
FastHoss
FastHoss is offline
Just curious,do you do your own sevice?The reason I ask is do you know the plugs have been changed,a/c cleaned,cables lubed,battery and grounds cleaned and greased
Old 07-09-2009, 07:56 PM
OldpanRay's Avatar
OldpanRay
1st Gear
Thanks for replying. Yeah, I do my own service, been doing it forever. Plugs have been changed every 5000 mi., I do everything according to the service manual. Even played with the gap on the plugs. No help. Changing the fuel filter at the recommended 25000 miles didn't change a thing. Only mod to the bike is the K&N air filter. Could be a mapping problem due to the K&N, I guess. Wouldn't think the EFI would be that sensitive. Thanks for any ideas you have.
Old 07-09-2009, 10:43 PM
oct1949's Avatar
oct1949
oct1949 is offline
Check to see if Ur getting any trouble codes..
Old 07-10-2009, 12:33 AM
OldpanRay's Avatar
OldpanRay
1st Gear
Hey. Just read how to pull the codes. Will do that tomorrow. Too bad no one makes a handheld scanner like I use on my cars. Would be a great tool. I do plan to take the bike in to the dealer, was just wondering if anyone else had a similar problem. Thanks for replying.
Old 07-10-2009, 04:09 PM
OldpanRay's Avatar
OldpanRay
1st Gear
SUCCESS! Pulled the codes and got Po132 & Po152. Front and rear O2 sensor codes rich. Manual says this puts EFI in open loop and if happening during break-in, ignore or clear codes. Since mine had been doing it a long time, I cleared the codes. Bike immediately ran much better, with no coughing or sputtering. Put about 40 miles on it and the codes didn't come back. Can't believe I put up with it this long. Didn't know how to pull codes before using this forum. I'll probably start doing that diagnostic check monthly. One thing though, why would HD not tell the check engine light to come on for these codes? Manual says it won't. I've apparently been riding with the EFI in open loop for 20xxx + miles. I know it's my fault, but had the light come on, I'd have been more apt to take it in to the dealer. Thanks, and I'll be on here daily from now on.
Just put another 50 miles on it with no problems, no codes at finish.
Old 07-10-2009, 07:08 PM
Harley Joe's Avatar
Harley Joe
Harley Joe is offline
It don't hurt to run a little fuel injector cleaner thru a tank of gas each time you change your oil....
SCEGU
10-12-2015 09:36 PM
WilliamJ
Exhaust System Topics
04-24-2012 07:23 PM
AlCherry
09-27-2009 06:46 AM
Fat Boy 07
09-09-2008 02:15 AM
Spool
12-11-2007 10:11 PM
Quick Reply: Engine sputtering, 07 FLHT
