Convert a single fire coil to dual?
Old 05-04-2010, 08:47 AM
KingPinVinny's Avatar
KingPinVinny
KingPinVinny is offline
Default Convert a single fire coil to dual?
My crane cams Hi4 system self distructed on me, was a single fire system. I put the stock sensor, ignition module, and coil back in. My question is: I have the accel hi output single fire coil, if I split the blue negative ignition coil wire into 2 wires into a Y, hook it up to both negitive terminals on the single fire coil so both coils fire at the same time, would it do any damage to the ignition module?
Old 05-04-2010, 09:16 AM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,201 Likes on 1,276 Posts
If I were in your shoes I would call the Crane Hi-4 boys and ask them this same question. I have seen several bikes that had bad electrical problems due to using the wrong coil. It might work for a little while but the coil will fail over time.
Old 05-04-2010, 09:57 AM
RHPAW's Avatar
RHPAW
RHPAW is online now
Received 13,891 Likes on 6,250 Posts
My experience with HI-4 is that they are for show bikes. They don't seem to last if you ride a lot. Mine was coil failure (twice). Never noticed ANY improvement in performance with single-fire. Went back to SE dual-fire, and it is reliable (years now).
What you are suggesting sounds like a future breakdown when it will be most inconvenient.
Old 05-04-2010, 02:36 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Thumbs down Single Fire
Totally agree , put a single fire on my 91 FLSTF and had nothing but problems with the hardware , coil went bad then the pick up unit behind the nose cone took a dump. Went back to the stock dual fire with a SE box(higher rev and better curve) and a SE coil, worked flawlessly. I would try to find a high performance dual fire coil if you think you need it.
astark
EVO
08-02-2013 12:29 AM
jfsgb
Shovelhead
05-10-2012 11:59 AM
RidemyEVO
EVO
11
06-08-2011 03:03 AM
kpolak
11-24-2010 08:51 AM
waynemags
EVO
05-28-2009 02:41 PM
Quick Reply: Convert a single fire coil to dual?
