Broken swingarm
Old 08-21-2010, 09:20 PM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,620 Likes on 2,094 Posts
Default Broken swingarm
I know this has been covered before but it can't hurt to bring it up again. If you feel the need to be a jackass and start ripping on the thread just move on. It might help someone avoid an injury.
I had read the threads about cracked swingarms here in the past and forgotten about them. My buddy has been having a stability issue with his bike for the last year. We talked about what it could be - tires, neck bearings, pivot shaft bushings. He had it to a couple shops, one replaced the neck bearings but the wiggle/wallow issue was still there. On the way back from Sturgis it got really bad. He took it to the dealer when he got home and they found the swingarm was cracked at the axle.
The repairs were more than his budget allows, so he brought it over here and I tore it apart last night. Long story short, when I removed the axle the right side of the swing was completely seperated. The only thing holding the right side in place was the shock and belt. There was a layer of dirty, oily sludge coating the swingarm and I suspect the crack was not visible or it might have been seen earlier.
Anyway take a look at these photos and check your swingarm if you are having any stability issues.
Attached Thumbnails Broken swingarm-rear-swingarm1.jpg   Broken swingarm-rear-swingarm2.jpg   Broken swingarm-rear-swingarm3.jpg   Broken swingarm-rear-swingarm4.jpg
Old 08-21-2010, 09:40 PM
hogginit's Avatar
hogginit
hogginit is offline
Appears to be a touring model, what year bike are we looking at?
Old 08-21-2010, 10:03 PM
Harleyrider_49's Avatar
Harleyrider_49
Harleyrider_49 is offline
Question
Daayyuuummm!!!!.......... Is this a tour'n model? what year?(nephew has an 09 SG) He's very lucky this thing stay'd, and did'nt fly all ta hell @ hwy speed.....damn'st thing i've ever seen.....so there are other's that have had this happen? As bad as this 1??
Old 08-21-2010, 10:14 PM
oct1949's Avatar
oct1949
oct1949 is offline
How bout some more info on the bike.
Old 08-21-2010, 10:17 PM
skratch's Avatar
skratch
skratch is offline
Received 4,222 Likes on 2,468 Posts
dayum! your friend is some lucky dude to have been riding that for a year and not kissed the pavement.
Old 08-21-2010, 10:24 PM
wb0zrd's Avatar
wb0zrd
wb0zrd is offline
It surprises me to see that the swing arm is not a solid piece of steel...looks like it is tube steel. I suppose this is to cut down on weight.
Paul in Colorado
Old 08-21-2010, 10:52 PM
rizzo's Avatar
rizzo
rizzo is offline
The scoot is a '96 FLHT with 80K on the clock. The swingarm is tube steel. This does happen more times than I'd like to think it does...
Here's another link I saw about the same thing in the touring section tonight
https://www.hdforums.com/forum/touri...swing-arm.html
Old 08-21-2010, 11:01 PM
pococj's Avatar
pococj
pococj is online now
Received 1,212 Likes on 462 Posts
Paul in Colorado
Correctly sized, a tubular piece is stiffer than a solid piece.
Old 08-22-2010, 12:11 AM
hatchetman's Avatar
hatchetman
hatchetman is offline
I think if mine broke, I would fish plate it & weld it. If you bought a new one, You should still fish plate it.
Does this scoot have a lowering kit on it? If it does, take it off & re set to factory so this won't happen again.
Old 08-22-2010, 02:07 AM
Tech23's Avatar
Tech23
Tech23 is offline
It's hard to tell because of all the dirt, but is the axle block missing? The axle block fits inside the swingarm and the axle passes through it. It helps to keep the swingarm from distorting (crushing) when the axle nut is torqued to spec. It looks like it is either missing in the second and third pic, or possibly an improvised part may have been in there?
Tech23
Quick Reply: Broken swingarm
