Which was first? Bad ignition switch, or what?
Old 03-23-2011, 06:16 PM
oldairboater's Avatar
oldairboater
oldairboater is offline
Loose connector if no corrosion or just a bad connector. Happens.
Old 03-23-2011, 08:02 PM
joutlaw's Avatar
joutlaw
joutlaw is offline
Stage IV
I had the same problem with my 05 FLSTC. The took the switch apart, cleaned the contacts, stretched the springs a little, coated it with dielectric grease and it's being going strong for the last year or so.
Old 03-23-2011, 09:30 PM
Grammaton's Avatar
Grammaton
Grammaton is offline
Originally Posted by piasspj
The lamps draw more current than a relay would. If you understand how relays work and wire it correctly it will lessen the chance of it happening again.
Even with the ign switch controlling the relay you will need to find a source of power for the lights.
This. ^^^^^^^^^
Lights draw a lot of current. Current means heat. I think the ignition switch should be stamped with what its current limit is, but I don't have one to look at. With extra stuff wired through the ignition switch, it gets hot and fails.
Jason3412
02-05-2021 03:42 PM
soulpatch
05-27-2019 01:14 AM
Am4wag
07-01-2013 05:12 PM
FlatBlackGlide
04-18-2012 05:43 PM
HOGNOT
05-15-2010 02:41 PM
Quick Reply: Which was first? Bad ignition switch, or what?
