I think I have a transmission pulley seal leak ..
But I'm not 100% sure. Ever since I bought my bike two years ago I've had the slightest leak that appears to be coming from the primary drain plug. I've changed the primary oil twice since then and each time I've replaced the O ring and wrapped the plug up with teflon tape. Now I've been reading that liquid thread sealant is better to use then the tape but I'm pretty sure that the plug is not leaking and here's why ..
The leak only manifests itself after I return from a ride. The oil collects and drips from the drain plug but I can feel a trail of oil coming from the back of the inner primary. When I look at my transmission sprocket it appears to be rather greasy and I've always noticed a small amount of greasy film on my belt.
So just curious if anyone else has experienced a transmission pulley seal leak before and if this sounds like what is going on with my bike. I'm trying to think of where else the leak could be coming from, it definitely seems as if it is coming from behind the inner primary somewhere and this is the only thing I can think of.
Anyways I'm probably gonna throw some of that UV dye in my transmission and check out that leak under a black light. Something like this should be safe to use in there right? http://www.autozone.com/autozone/acc...er=835775_0_0_
Yes, friend of mine has an 07 dyna and it leaked on the primary shaft seal. Had about 16k miles when it started. He replaced it himself with the service manual, not too bad of a job but takes some time. Used Genuine James seals, they are much better than HD seals. Had to make his own locking bar which isnt hard. Also added some liquid gasket to some other seals that looked bad like the shift shaft seal. Now much better.
Received 1,540 Likes
If you are going to pull the inner primary it really doesnt matter which one is leaking, just replace all the seals.....shifter shaft, starter jackshaft, etc. The primary drain plug really doesnt need anything but the o-ring....and dont over tighten it.
Yo yo that changed out my tire unwittingly adjusted my belt just slightly out of alignment. Noticed the belt out of alignment looking for the source of the weep around the rear of my primary. Realigned belt and adjust tension weep stopped.
And I guess another thing I've noticed about my bike is I have to adjust my belt like every hundred miles or so. Seems like I shouldn't have to adjust it so frequently. Not sure if this has anything to do with my oil leak just throwing it out there I guess
be glad you dont have a old HD you couldnt tell where the leaks were coming from .
showroom floors had cardboard under the new ones .
I had a similar leak on my 07 Superglide. It was a bad tower gasket that fits over the shift lever and is located between the inner and outer primary covers. It looks like an aluminum foil gasket with adhesive on one side. When you pull the outer cover off, look down toward the inner primary where the shifter shaft comes through. The tower gasket should be attached to the inner primary at that spot. If the gasket is oblong or just hanging on the shaft, replace it. Make sure you degrease the spot before you attach it as that adhesive on the gasket is kind of thin.
