Zumo 660 Wiring Help Please
Just got the HD Zumo 660 and I am not sure about the wiring. I intend to wire it up to the accessory switch using the Deutch connector under the seat. My question: the wiring harness with the Zumo has fused end with a black wire. I know those are the hot and ground leads that I wire into the Deutch connector. Now the other connectors on the harness I assume are for a Harley specific mount, is that correct? I plan on getting the a mount from Iron Aces Speed Shop, since I don't want wires going down my 12 inch apes on my RG. So my thinking is that I can just disregard those other connectors and tie them off. Am I on the right track?
This is the Iron Aces Mount I will be using http://www.ironacesspeedshop.com/pro...-gps-mount.cfm
I figure this is the best way to hide the wires. Thanks for the help.
Love that mount you're going to use. Will look into that when I step up to the Ultra.
I simply fabricated an adaptor harness to convert my SAE battery charge plug to the common 12V female cigarette lighter style accesory plug. This is great for me as the same acessory plug powers my Zumo 660, my heated gear, and ipod . I don't have the Harley specific accessory Zumo 660 kit, I have a standard store bought version that uses a common 12V accesory plug. I also just used a RAM mount, as I have 2 other bikes (using the same RAM setup) that all can use the same GPS . Me personally don't need my GPS installed all the time, so I went the "temporary as needed " type install .
I'm not sure how the wiring goes but it looks like the wiring is pretty well discribed in the manual that is available as PDF. On my wiring BTW it is the red wire that is 2A fused. It is connected to a blue, switched live wire. What baffles me is that you go out to buy a HD Zumo (so the Roadtech) which is specifically designed to work with a Harley's HK radio and then go for a non compatible mount which completely destroyes the compatibility. You could have saved yourself hundreds of Dollars by buying the normal Garmin Zumo. Spending some of these savings could have paid for shop installation of the thing.
Yup. I got my warranted "refurbished" universal 660 for $180 off ebay. Love it works awesome, and can see the screen good in the sunlight, I can also swap the mount and run it in my cages.
The Zumo's come with 2 mounts - one for the bike which gets wired in and one universal mount/power plug for cage use.
The mount that Harley offers for Road Glide installation is a handlebar mount. In order to use that I would have to run the wires down the handlebars, since I have internalized wires I don't want to have extra wires on the outside of my handlebars. Using the mount that I bought, I might conceivably be able to have the radio interface go into that at a future date. It's a cleaner install to me.
