Crack in V&H Heat Shield - Repair?
I found this today while cleaning the bike. It wasn't there during the last washing a few weeks ago.
I've contacted V&H customer service. Is there anything I can do to prevent it from getting worse until I can replace it?
Is there room underneath to get a bit of that two-part (usually black and white) epoxy putty you find in most hardware stores that dries hard as steel in a few minutes?
I don't suspect the heat will be an issue either.
Looks like its gunna get Worse , the way its hangin on there , looks like you might need some type of Clamp for support .
Received 3,222 Likes
Kinda looks like a stress crack. Is the clamp that holds the heat sheild in place anywhere near the crack?
