Air Cleaner
03-29-2014, 06:41 AM
Air Cleaner
On a 08 Street Glide with Rhinehart true duals with a stage 1 download can I bolt the HD heavy breather with out having anything else done to it?
03-29-2014, 07:15 AM
Quote:
Originally Posted by
kdawg187
Yes. The stage-1 download should cover it.
03-29-2014, 08:47 AM
I had a Stage 1 download with slip-ons an a SE ac, was not impressed. Recommend a fuel tuner.
03-29-2014, 08:51 AM
You'll be much happier with the performance with a fuel tuner. JR
03-29-2014, 06:24 PM
May just have to look into the fuel tuner then....thanx
03-29-2014, 06:32 PM
kdawg187
XIEDS's should be added at minimum. or try to locate a used V&H Fuel pak and run both together. It will run well and all you need unless you are going to do any engine mods
03-29-2014, 06:44 PM
kdawg187
There is nothing else you Need to do to it, but you might be underwhelmed with the outcome...a bit warm too.
Here is a good overview of different choices of what to do with the EFI when installing free flow intake & exhaust-
https://www.hdforums.com/forum/ignit...uning-etc.html
03-29-2014, 07:37 PM
checkers
XIEDS's should be added at minimum. or try to locate and V&H Fuel pak and run both together . It will run well and all you need unless you are going to do any engine mods
I have both on my bike and it runs great/cool(my performance mods are in my signature). I don't plan on any other performance mods so I don't see the need for a tuner.
Monarq
07-26-2015 03:07 PM
LouDiamond
06-29-2015 09:38 PM
brokenwing
03-29-2015 10:09 PM
RMH1120
11-16-2009 03:20 PM
Samores
02-16-2009 02:46 AM
