2004 FLHRI Suddenly no start
Old 11-21-2014, 06:24 PM
alottamiles's Avatar
alottamiles
alottamiles is offline
Default 2004 FLHRI Suddenly no start
Spark present, Fuel pressure and Compression Turns over but will not fire. Battery at 13.6vdc. No Codes. Any suggestions
Old 11-22-2014, 09:15 AM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
Cracked fuel pressure regulator housing?
Old 11-23-2014, 09:57 AM
jimvac49's Avatar
jimvac49
jimvac49 is offline
6th Gear
I had a fuel pressure regulator crack once. It would let the bike idle but wouldn't take gas. Limped it home a couple of miles. Not a smart thing to do. The lean condition made that engine very hot,
I wonder if the injectors are clogged or not firing? ECM?
Old 11-27-2014, 12:40 AM
dfwhockey17
^If the fuel level gets too low then the bike turns over but won't fire as the fuel is just spraying back into the tank. A fairly elementary diag is to take the gas cap off, shine a flashlight into the tank and see if fuel sprays everywhere when the ignition is turned on and the fuel pump is priming....
fish425093
05-21-2021 09:40 AM
old cat
05-30-2019 05:19 PM
ZachGrove1
09-08-2018 12:26 PM
Kate58
15
12-24-2017 02:31 PM
KevinKruuz
08-11-2012 08:45 PM
Quick Reply: 2004 FLHRI Suddenly no start
