Throttle cable question for FLTCUI
Old 04-26-2015, 07:44 PM
saz's Avatar
saz
saz is offline
Default Throttle cable question for FLTCUI
I'm looking at putting a set of 14" apes on my 96 FLTCUI but I am having a very hard time finding cables. All of the cables I find are for carbed bikes. Wouldn't cables for fuel injected Electra Glides work if I had the length? I could go with some 10" bars and retain all the stock wiring and cables, but what fun would that be.....
Old 04-27-2015, 02:51 PM
saz's Avatar
saz
saz is offline
Nobody?
Old 04-29-2015, 12:33 AM
2deuceguy's Avatar
2deuceguy
2deuceguy is offline
Check out the jp cycles catalog. Not sure where to find on their website but in their catalog they have kits for different size bars. so far I've had good luck with those fitting
Old 04-29-2015, 08:29 AM
Lakerat's Avatar
Lakerat
Lakerat is offline
There is no difference between cables for carbed and EFI.
Old 08-11-2015, 07:33 PM
saz's Avatar
saz
saz is offline
Are you sure? All of the part numbers I have seen are different.......
Old 08-11-2015, 09:38 PM
Ray on the drums's Avatar
Ray on the drums
Ray on the drums is offline
Received 1,134 Likes on 512 Posts
I had a little bike shop I like to deal with sold me and then cut off an inch of cable and resolider another ball back on the end. No big deal to them and it looked and has been working great.
Made me think if you could maybe find a company that would custom make you one. Taking your dimensions, cable, sleeve and the needed ends.
Or get one close and cut and change the ends as needed. The right pieces and it wouldn't be that bad.
I had a 1984 Electra Glide and the only cable I could find even though it was all stock needed to be cut down.
Old 08-12-2015, 09:24 AM
Lakerat's Avatar
Lakerat
Lakerat is offline
I'm sure that when I converted my '98 from EFI to carb the original cables worked just fine. Did a bunch of research about the conversion and never once did anyone say anything about having to swap the cables.
Old 08-12-2015, 09:52 AM
saz's Avatar
saz
saz is offline
Good to know! Thanks guys!
jf7689
EVO
09-11-2018 09:17 PM
Casey Klock
04-08-2018 07:11 PM
dlun12
07-10-2013 12:21 PM
mphillips
09-07-2009 02:10 PM
Steel
01-15-2008 09:32 AM
Quick Reply: Throttle cable question for FLTCUI
