Toe heel shifter
Old 07-13-2015, 07:38 PM
fnunez's Avatar
fnunez
fnunez is offline
Default Toe heel shifter
Ne tips on making smoother shift on either heel or toe? Personally I like the heel shift but don't want to be stomping the hell out of it feel like I'm gonna break it! Thank
Old 07-13-2015, 07:42 PM
davidwruth's Avatar
davidwruth
davidwruth is offline
Find an angle of the shift leverthat works best for you. Once you use it more slamming it won't be as usual as now. Heim joint shift rods seem to make it better in my opinion
Old 07-13-2015, 07:46 PM
fnunez's Avatar
fnunez
fnunez is offline
Do you recommend using the heel instead of the toe?
hogcowboy's Avatar
hogcowboy
hogcowboy is offline
I've done just that for well over 200k miles on different Harleys. If you really watch and pay attention you'll see you aren't really "stomping" on the heel shift as much as it looks like. I agree it does look like it but it really is just a lite but positive touch.
Old 07-13-2015, 07:49 PM
fnunez's Avatar
fnunez
fnunez is offline
Yea true u got a point there man thank for your I'mput. I try shifting with the toe but since I have a flat platform it's harder for me to lift with the toe so I find it easier shifting with my heel
Old 07-13-2015, 09:03 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
There is no recommendation; it's all personal preference. After a couple of days, I couldn't wait to take my heel shifter off. I never used it and it was just in the way of foot position options on the floorboard. Don't miss it at all.
Old 07-13-2015, 09:23 PM
fnunez's Avatar
fnunez
fnunez is offline
I want to use the toe shifter jus need some getting use to that's all
Old 07-13-2015, 09:30 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Don't forget it's adjustable too. Slide the shifter off the shaft an position it to suit YOU!
Old 07-13-2015, 11:45 PM
fnunez's Avatar
fnunez
fnunez is offline
Yea I'm gonna have to try that jus came back from a ride and actually felt it smoother when using my heel instead of picking up my whole foot I jus lofted my heel way smoother....but I will adjust and try the toe
Old 07-14-2015, 12:05 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
We set our heel shifters as low as possible to make the shift without it interfering with the floorboard. Then all you need to do is slide you foot back and a gentle tap with your heel is all you need...
Quick Reply: Toe heel shifter
