General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
That picture of my clean piston in post 2 is how it looked at 100K right after I took the head off. It had been eating coolant since new. Not a whole lot till near the end. It would empty the reservoir bottle about ever 6 months if you let it. I just kept it full. Seriously doubt the antifreeze made it any cleaner. Let it get a little low during the winter and pretty sure that finished it off. Ran fine till one morning when cranking it up. Made a loud crack bang. Then even more crazily racket like electrical arcs and a motor running on the end of a whip bouncing around since the starter was no longer hooked to the motor.
It is easy to see when a head gasket has gone, and where, by which piston is clean. Mechanics have diagnosed internal coolant leaks like this for years.
Just don't drown it. You can't compress a liquid, so too much water equals lots of broken bits.
