Proper Engine Warmup
Old Jun 27, 2005 | 02:25 PM
HDF Tech's Avatar
HDF Tech
Default Proper Engine Warmup
Warming up your bike
Working at a custom shop gives one insight on a lot of self inflicted problems. Quite often customers come pick up their bike, jump on and take off in 10 seconds; bad… really bad. The engine in an air cooled v-twin motorcycle is made up of aluminum and steel parts. Aluminum heats up twice as fast as steel and expands at a different rate. Not allowing the engine to warm up leads to leaking gaskets, scored cylinder walls, excessive carbon buildup on the pistons and valves, etc… base gaskets at the junction between the cylinders and crankcase are the most affected. You have steel cylinder studs, aluminum cylinders and heads, steel valves and rings, aluminum pistons, steel cylinder jackets, etc. you get the picture, lot's of different materials all expanding at different rates. Oiling in a v-twin is ok at best and it takes a while to get it circulated through the engine, let alone up to temperature and doing its job.
Rule to live by: If you put your finger on the rocker box of your bike and can leave it there, you are not ready to go. It should be hot enough to be uncomfortable to the touch.
This process could take anywhere from 2 to 7 minutes depending upon ambient temperature. So save yourself engine life and gaskets by warming up your bike properly. It is the cheapest thing you will ever do for your bike
Source: http://www.azthundercycles.com/service.html
ranjet
Ironhead
Jan 21, 2014 07:34 PM
trnewman
May 11, 2013 04:30 PM
Jefferson
Exhaust System Topics
Nov 20, 2009 07:19 PM
Moonor
The General Motorcycle Forum
60
Oct 29, 2009 12:17 AM
HDDyna2006
May 26, 2008 11:40 PM
