Red or blue (loctite)
My main consultant, the previous owner of my '83 Shovel, recommends using Loctite red on just about everything. I've always used blue but this is my first Harley project. I just wanted some reassurance on this. What do you use? where? why? After watching the video below, I'm a lot more apprehensive about red. I don't want to need a torch to remove bolts from my powder coated frame but if that's what it takes to get this thing to hold together, I suppose I should. I don't care to have a footpeg rattle off on the freeway.
BTW. You can remove a bolt with red locktite without heating it...but don't!!! The red stuff is strong enough to ruin threads when cured! Heating softens it to prevent damage.
Before taking any other advice, check their website! There is no such thing as 'blue', as I once knew it, as the darned stuff all seems to come in red bottles! There are also many versions, so read the specs and chose wisely. The traditional 'red' type is a definite NO-NO - that darned stuff used to set rock hard. But then perhaps your 'expert' has never come across that stuff!
Don't guess, check for yourself. Most of us want to dismantle the thing later. On the website I just checked there are 33 different Loctite branded thread-locking compounds.....
Received 2,858 Likes
SIDECAR BOB (01-18-2017)
If ya screwed up and used red, and there's no easy way to get heat on the nut/bolt/screwhead without risking damage to surrounding finishes, here's a trick: use a soldering gun.
Put the tip on the head of the fastener, give it 30 seconds or so, maybe a bit less if it's delicate paint, let it heat soak a minute, and give it a try.
The following 5 users liked this post by IdahoHacker:
crazytown (01-18-2017),
huggies (01-18-2017),
jon loder (01-16-2017),
mcraige65 (01-20-2017),
Sparkybob477 (01-19-2017)
