Pain between shoulder blades
Thought I would post this up and see if any one else may have had these type of issues. On my RGS got in about 1.5 ride or so Saturday. Started noticing a burning aching pain right between my shoulder blades. I could stretch out for a second or 2 on long stretches but still ached pretty good. Now I have upgraded my seat with a lower back support and have 0 complaints there. I have adjusted my stock bars back about 1 " and the length feels just right. What else should I look for (other then the fountain of youth). Just remember having issues like this last year on the Heritage.
Not an expert here for sure but do have a similar problem. (along with a lot others at 68) That area for me for some reason is sensitive to cause pain for some reason.
On my bike takes at least a 100+ miles to cause a problem. My friends CVO Dana has a narrow BMX straight bars and 5 miles on that thing will cause my clutch hand to actually quit working in my fingers and I have to use my palm. On it, my knuckles face fwd. On mine, there at 45 degrees to the wind and way back. So bar angle and how you are hunched over affects me.
I hit the gym regular. I use a 15lb dumbell in both hands hanging at my wast. I do three sets of about 10 reps in front of a mirror. Sort of a rolling motion isolated to my shoulders. 3 set fwds and 3 set back. Go easy if you try this and work up weight you are comfortable with and reps.. It's easy to fill a burn when doing this, at least for me.
I been traveling for the last few months and when I get back into the gym, it will be 10 lbs and maybe 2 set.
If you can strengthen that area, think it will help. Be forewarned, my brother in law had a similar problem and he had a bad disk way up high causing his pain. Different from the normal low bad disk that causes lower back pain. They actually went thru from the front in his throat to fix it.
Thanks for the tips guys..I have considered bars but didn't want to just start throwing money at it...I am only 5'8" and 14" bars seem huge to me. I do exercise regularly, 5-6 times per week. Run, rowing and some light lifting. Will give working on the shoulders/upper back some more focus and see what happens..
[QUOTE=Ashnic;15952026]Thanks for the tips guys..I have considered bars but didn't want to just start throwing money at it...I am only 5'8" and 14" bars seem huge to me.
I am 5'8" also. The 14" bars I put on aren't really that high. My hands are right at shoulder height. The other thing you need to be aware of when changing the bars is wrist angle. The bars I installed are perfect IMO. When I am holding the grips, my wrist is not twisted or bent. Best ergonomic position, no numbing sensation.
Received 8,249 Likes
I've experienced the same issue with the tightness between my neck and shoulders. I solved that problem by going to taller bars which gave me more flexibility in my arms and shoulders. If you like apes, they make mini-apes that aren't so tall to where the height would be uncomfortable for you. I've even known some that went to bars that had a longer pull back to where the grips were closer to their body and that helped. Good luck
I think wrist angle may have more to do with it..out working on bike earlier and starting really focusing on grip vs tension in my bike and discovered my hands are turned out not straight. When I let go of the grips and straighten my wrist the tension in the center of bike is relieved..
If I go to apes ( I believe 12" is as tall as I would go) how do I know what the wrist angle may be? Also how do they measure apes?
