Riser Bushing Bolts
Old 03-06-2017, 08:32 AM
lcsig229226's Avatar
lcsig229226
lcsig229226 is offline
Default Riser Bushing Bolts
Hi, I did an install on my 2017 Street Glide Special of a set of Paul Yaffe 12in Monkey bars. I also used a set of Arlen Ness Riser Bushings to replace the rubber OEM ones. I noticed that the factory bolts do not come to the top of the threaded hole on the handlebar bracket...probable a quarter inch shorter. Should I order a longer set, if so can anyone recommend a part number for me. Thanks.
Old 03-06-2017, 10:26 PM
dfwhockey17's Avatar
dfwhockey17
dfwhockey17 is offline
You are fine, with stock rubber bushings you want some room to be able to tighten the bolts as the rubber wears and the risers become loose. With your poly bushings you won't have this issue as early on but you will end up tightening them at some point. Did you use the Yaffe top clamp with set screws to keep the bars from rolling back in the clamp?
lcsig229226
Milwaukee Eight (M8)
03-08-2017 06:18 PM
glock221
02-11-2012 11:18 AM
yandeltx
09-29-2010 07:11 AM
jaysonL
12-10-2008 06:55 PM
superglider
09-18-2006 12:17 AM
Quick Reply: Riser Bushing Bolts
