Carlini High Roller Riser help
Old Feb 11, 2012 | 10:30 AM
glock221's Avatar
glock221
Default Carlini High Roller Riser help
I got the HIgh roller risers. I am pretty green when it comes to wrenching. I am trying to figure out how to loosen them to adjust my bars. The only thing I see is an allen bolt under the front side. Do I just loosen this?
Old Feb 11, 2012 | 10:40 AM
Kowan's Avatar
Kowan
You should see 3 bolts. The one at the front, one at the rear, and a set screw.
Blue Loctite that can be found at any auto parts store, should be used on the clean threads.
Loosen all three bolts on each riser to adjust the bars to where you want them.
I would remove one bolt at a time to apply loctite, re thread that bolt, repeat and then adjust and tighten.
The set screws are tightened last once you have the bars where you want them.
Old Feb 11, 2012 | 11:12 AM
glock221's Avatar
glock221
Thx Kowan, do I loctite the set screw?
Old Feb 11, 2012 | 11:18 AM
Kowan's Avatar
Kowan
I did on mine. I have the Carlini "Boob" risers with the set screw.
REW13
Nov 1, 2017 08:53 PM
lcsig229226
General Topics/Tech Tips
Mar 6, 2017 10:26 PM
tbone4760
Apr 26, 2015 11:49 AM
OldTyme
Aug 10, 2012 03:47 PM
yandeltx
Sep 29, 2010 07:11 AM
