Correct procedure with Loctite...
Old 11-30-2013, 11:44 AM
PhilG57's Avatar
PhilG57
PhilG57 is offline
Default Correct procedure with Loctite...
To adjust the spring clamps on my windshield, I loosened the acorn nuts holding the clamps. I then noticed the screw threads had blue Loctite applied. When re-tightening the nuts, what is the recommend procedure: do I just "re-use" the existing Loctite or should I apply a drop of new Loctite? I realize this application is not really mission-critical but I would like to know the recommended procedure for all cases. Many thanks.
Old 11-30-2013, 11:53 AM
Wanna Ride's Avatar
Wanna Ride
Wanna Ride is offline
Loc-tite is typically a "one-time" use. Once it's applied and cures, it "bonds" to the threads. So once broke free, it no longer has bonding properties.
To properly reapply, you should remove the fastener, clean the threads, and reapply.
http://www.loctite.com.au/aue/conten...sers_Guide.pdf
Old 12-01-2013, 11:46 AM
PhilG57's Avatar
PhilG57
PhilG57 is offline
Thanks for the advice and the link - both have been very helpful. And from a fellow Chicago-based person at that. Many thanks again.
Old 12-06-2013, 11:09 PM
Wanna Ride's Avatar
Wanna Ride
Glad I could help. Now go ahead and start those winter mods, cuz' after today, it looks like we aint taking bikes out of the garage anymore for a few months.
A206Driver
02-23-2015 08:20 PM
kaiser343
10-21-2013 06:56 PM
sambo42xa
05-17-2013 01:13 AM
bzxgdk
08-01-2011 01:52 PM
artz
12-27-2010 08:56 AM
Quick Reply: Correct procedure with Loctite...
